June 23, 2021 at 3:15 am
jkm242
SubscriberI would like to change the x and y axes of my plot to be position for the x axis and field magnitude for the y axis, but it seems like the only options I have are the default variables, frequency and phase. Is there a way to change these? Thank you
June 23, 2021 at 8:03 amAndyJP
Subscriberuncheck the "default X" box, then you put your Y in X, and vice versa.
When editing the fields report, don't forget to select the geometry (path, line) along which you are plotting.
June 29, 2021 at 12:21 pmPraneeth
Bbp_moderator
Please go through "post processing and generating reports" chapter of the HFSS help document to see full details on the post processing capabilities of the tool. You can also check "sweeping a variable in a report" section for your need.
All the very best.
Viewing 2 reply threads- The topic ‘Changing the Variables in HFSS Results Plots’ is closed to new replies.
3597
1283
1107
1068
983
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
