May 13, 2024 at 1:48 pm
Matthias Sauter
SubscriberHey there,Â
I am currently running a parameter sweep (nested sweep). Within this sweep parameters the height of my device (pillar) changes aswell. I have a monitor right at the top of my device. Is there a way to always set the position of the monitor equally to the top of my device?Â
Best regards,
MatthiasÂ
May 13, 2024 at 4:36 pm
Guilin Sun
Ansys EmployeeYou can use analysis group, and set the monitor and the pillar inside the same analysis group. Please refer to this example: MetamatePLerial parameter extraction - Smith
or use script inside "model" to move the pillar and the monitor at the same time.Â
If it is for transmission measurement, no need to move the monitor.
May 14, 2024 at 7:43 am
Matthias Sauter
SubscriberYes, that worked. Thank you.Â
- The topic ‘Changing the monitor position while sweeping’ is closed to new replies.
