Changing the contour colours
    • Shivani
      The values of my resultant force changes with height but the contours colors are uniform for the entire area.Is there a way I change the contour color or appoint certain bandwidth of color so that the change is more apparent?
      You can type a number into any value on the color scale (except the bold text, which is the Min or Max value in the result)
    • julianiiim
      Is it possible to change the Min and Max values (bold text)?, because I need to compare two contour images from different simulations about the same system (different initial and boundary conditions on the same domain), to visually observe the differences. I have the latest version of ANSYS Workbench.n
    • das.3
      Yes, you can set the contour range to 'user defined' during post processing and type the desired values manually.n
  • The topic ‘Changing the contour colours’ is closed to new replies.
