November 23, 2023 at 11:17 am
Nathalie Smedts
SubscriberMy problem involves heating an object in an oven (190°C). When changing the mesh element size, the average temperature of the object changes over a wide range (almost 20°C after the same heating time). Because all the other factors were kept equal, this (relatively) huge variation does not seem right to me. A more precise example: if I change the mesh element size from 0.015 to 0.012 (number of elements: 60051 -> 103371), this results in a temperature change of 6°C.Â
While modelling other problems, the temperature only changed a few decimals. Consequently, I am worried that this difference can't be right.
Can you think of any possible mistake I could have made that could have caused this?
November 23, 2023 at 1:59 pm
SRP
Ansys EmployeeHi,
Change in temperature due to a variation in mesh element size could be due to the numerical stability. You can try perform grid independent study so that results will be independent of mesh.
- The topic ‘changing mesh gives total different results’ is closed to new replies.
4607
1515
1386
1209
