Electronics
Electronics
Changing font size across the GUI
    • vinay91
      Hello, I believe this should be someplace fairly obvious but I am unable to find it - is there an option to change the font size across all panels on the GUI on Electronic Desktop?n
    • VivekKamble
      nMay I know the need for changing the font size? Have you changed your Monitor resolution or using a 4K display? nPlease let us know.nRegards,nViveknn
    • vinay91
      I dont believe there is a resolution issue. The display is not 4k. I am used to larger font sizes on other EDA software and would prefer the same on HFSS.nn
    • AndyJP
      Ansys HFSS/Maxwell was never designed for modern PCs. It was not updated for 13 years at all, but generally the same UI as in the first windows release was kept till ver 2019.nNow they started using TTF fonts and Windows10 TTF scale.nHowever, the report engine is the same as 13 years ago, and you have to use a loupe to read labels there on 4K displays. I hope it will be fixed in ver 2021. But honestly, the whole report plotting engine needs revamping. Particularly the Smiths chart is horrible.n
  • The topic ‘Changing font size across the GUI’ is closed to new replies.
