Changing elemrnt type in workbench
    • SriVin
      Hi all ! Thank you for the support till now !
      Initially workbench always used SOLID186 elements for all material if it was a solid. Later I could change the type of element chosen by altering properties in mesh generation. I could generate SOLID185 (generally used for soil). However I can't generate SOLID65 used for concrete by changing mesh properties. I used a command as show in following pictures.
      As you can see it created SOLID65 and static analysis was successful but
      In modal analysis following error popped
      1) How can I rectify the error ?
      2) Is SOLID186 or 185 better than SOLID65 for modelling concrete ? ( Right now I need not check cracking of concrete, I understand SOLID65 can crack)
      Thank you
Viewing 0 reply threads
  • The topic ‘Changing elemrnt type in workbench’ is closed to new replies.
