October 30, 2024 at 12:43 pm
nobrien
SubscriberHello!
I'm using Fluent 2021R2, and I am trying to change the under-relaxation factors for the different equations with the Pseudo-Transient method. Through the graphical interface, I can change momentum, pressure, k, omega, body forces, density, and Turbulent viscosity. While that could work, I'd like to control these factors from a text-command so I can run them on an HPC without setting up the case in a GUI.
The text command for changing the pseudo-transient relaxation factors is in /solve/set/pseudo-relaxation-factor, but this text command does not let me change the factors for momentum or pressure equations. Is there a text command that I am missing? I couldn't find it in the text command guide or just by snooping around the text-command menus. Would I instead need to use a scheme command to set it manually?
October 30, 2024 at 1:31 pm
Forum Moderator/solve/set/under-relaxation perhaps?Â
October 30, 2024 at 2:31 pm
nobrien
SubscriberHmm I'm not seeing that option. Here is what I'm seeing:Â
Maybe I can look in another menu for the under-relaxation option, but it looks like "relaxation method", "high-order-term-relaxation", and "pseudo-relaxation" all lack the option to change the pressure-momentum relaxation factors...
This is the page showing the factors in the GUI, but I would prefer to change the relaxation factors through a text command.
October 30, 2024 at 4:16 pm
Forum ModeratorI'd missed that you were using an older build, it's there in 24R2. Some of the options have changed so it's possible the UR factors weren't fully exposed for pseudo-transient at 21Rx.Â
October 30, 2024 at 8:05 pm
nobrien
SubscriberAh, no worries. I figured that may have been the case.
Thanks, Rob!
6625
1311
