October 24, 2023 at 3:43 am
vighnesh
SubscriberHello there, im new to Ansys CFD so just a quick clarification from anyone out there. I have a pipe geometry of a shape "S" with an orifice sensor at the inlet. The issue is i had given the diameter of pipe, orifice in millimeter(unit) which i was supposed to give in micrometer. So can i change the parameter now. I tried to do so but some warning is poped up saying some edges and radius values have zero length and will be deleted. Any help here??
October 24, 2023 at 3:48 pm
Forum ModeratorIf you have the CAD built you can scale in the solver. CAD kernels and microns tend not to mix well so it's also a good idea to scale up to build the geometry and back down in the Fluent solver.Â
October 25, 2023 at 2:03 pm
October 25, 2023 at 3:23 pm
Forum ModeratorI suspect the existing path is breaking the tolerance if you set that in microns. Ie the curves etc have collapsed.Â
November 3, 2023 at 3:36 pm
vighnesh
SubscriberIs there any workaround? i tried everything i could...
November 3, 2023 at 3:53 pm
Forum ModeratorOther than build in mm and scale?Â
- The topic ‘Change of diameter of a pipe.’ is closed to new replies.
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
4597
1495
1386
1209
