November 23, 2023 at 3:47 pm
pv00170
SubscriberI am working with this bridge which has stiffeners (steel beams) between girders.
In the results, two of them seem to grow somehow when changing the scale.
I am wondering why this enlargement occurs only for two of them and not all of them.Scale 1.0:
Scale 400:
Is it because the deformations?
Transversal:
November 24, 2023 at 2:38 pm
Ashish Khemka
Forum ModeratorHi,
Please check if the parts are properly connected. You may try running a modal analysis as well. If the parts are shell bodies and bonded then check if you have used MPC algorithm for the contact. MPC algorithm gives proper result display for shell elements.
Ashish Khemka
November 25, 2023 at 9:11 am
pv00170
SubscriberThese are beam elements attached to 3D solids. All connections are the same for all beams and it works properly for the rest.
I have tried the following:
- use MPC as suggested
- extracted the beams again (from zero)
- delete the connection and duplicate from a beam which does not show this issue and assign it to the mentioned beams
but the problem is still there.
- The topic ‘Change in shape when looking at results’ is closed to new replies.
5754
