October 17, 2023 at 9:03 pm
thach-hoang.nguyen
Subscriber -
October 18, 2023 at 6:02 am
October 18, 2023 at 6:14 am
thach-hoang.nguyen
SubscriberHello,
Thank you for your reply. But i need to rotate the section so the plane of the section is the plane of cylinder coordinate system of an another model.
October 18, 2023 at 6:21 am
Devendra Badgujar
Forum ModeratorHello Hoang,Â
You can do this using the Move tool. Move tool can be used to translate or rotate to realign/reorient the geometry with another model.
You can learn more about basics of Move command from this Discovery SpaceClaim: Getting Started Tutorials - Ansys Knowledge
DevendraÂ
- The topic ‘Change axis cross section’ is closed to new replies.
- Add-in Error Excel
- Spaceclaim problem
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- New Computer
- Inconsistent Script
- MISSING SIMULATION SECTION/RIBBONTAP
- Unable to attach to geometry file 2025R2
- How would I select specific components and all bodies under it?
1530
1386
1210
