3D Design
3D Design
Change a email adress or name ANSYS Account
    • krzysztof.reszuta
      Hello
      How to change my account email and username in my ANSYS Account  on the page    https://myaccount.ansys.com/account
      Solution provided in help doesn't work due to wrong http address http://ansys.online/profile
      To update your ANSYS Account profile information, go to http://ansys.online/profile. Sign in to your ANSYS Account, then edit the fields as desired
    • Naresh Patre
      Hello kres_nxt
      Email address cannot be changed once it has been registered. You will have to register using new email and create a new account.
    • krzysztof.reszuta
      Hello Naresh Patre
      Thank you for the answer.
      In that case it is possible to delete current account?
      • Naresh Patre
        kres_nxt I will check it and let you know. However, I don't see any reason for deleting your current account. You can just create a new account and start using it and leave the existing account as it is.
    • Naresh Patre
      kres_nxt
      There doesn't seem an option for deleting an account once created. So as mentioned earlier,  just create a new account and start using it and leave the existing account as it is.
  • The topic ‘Change a email adress or name ANSYS Account’ is closed to new replies.
