3D Design
3D Design
Chamfer with Variable Radius Round Corner and Straight transition?
    • Gerry Brown
      Hello. In other apps it is very easy to create Chamfer with Variable Round Corner and Straight Transition. But seems it is impossible to create the same thng in SpaceClaim.
      I can create Chamfer, add Round Corner, enable "Edit as Variable Radius" and set one radius to 0. But now there is no any option to turn off Smooth transition. I can't believe that sutch a simple and basic thing not available in SpaceClaim. Any ideas?
    • Atharv Joshi
      Hi Gerry,
      Let me check this and get back to you.
      Thanks and Regards
      Atharv
    • Gerry Brown
      Seems i almost figure how make it. If i click to inner corner magenta dot and change value from 100% to 0%, variable radius lines became straight. Next i can drag inner corner arrow near that dot, press Space key and and enter value 0.
      But problem partially remains because it is impossible simply enter radius value of round corner that will match to exact chamfer size. So i must guess it. For example if Chamfer size is 2mm, and if i enter round corner 2mm raduis – it feels too small. For 2mm Chamfer i need to enter corner radius something like 4.2mm.
    • Gerry Brown
      I guess it could be mush easier if it was an simple option to apply Blended Miter Corner for Chamfer.
    • Atharv Joshi
      Hi Gerry,
      You can use the approach of moving the lower magenta colour dot from 100% to 0%. I will see if there's any simple option to apply straight transition.
      Thanks and Regards
      Atharv
Viewing 4 reply threads
  • The topic ‘Chamfer with Variable Radius Round Corner and Straight transition?’ is closed to new replies.
