December 15, 2022 at 5:07 pm
William Grissom
SubscriberHi, I have been issued a license by Ansys in a file called 'LSTC_winlic.txt' which I have tried to use without success. It appears to give access to MPPDYNA (Option: Revision 13), MPPDYNA_971 (Option: Revision 6), MPPDYNA_970, MPPDYNA_960, LS-DYNA (Option: Revision 13), LS-DYNA_971 (Option: Revision 6), LS-DYNA_970, and LS-DYNA_960. It lists a key at the bottom and at the top it lists 40-digit SERVER and additional 'Interfaces'. I have tried unsuccessfully to run LS-DYNA of various versions (the key appears to let me use MPP or SMP versions 13 or 6 so I have been trying 13 smp and mpp, but also 12). I have tried running it both from LS-RUN after loading in the license, and from the command line after checking that the two environment variables point to the local license. However I always get the same 'Error Bad license keys!' message in my output/log. I must be missing something? Below is an example output.Â
Thanks,
Will Grissom
 License option : check local license only
 *       ANSYS 2021 R1      LEGAL NOTICES       *
 * Copyright 1971-2021 ANSYS, Inc.  All rights reserved.    *
 * Unauthorized use, distribution or duplication is       *
 * prohibited.                         *
 * Ansys is a registered trademark of ANSYS, Inc. or its    *
 * subsidiaries in the United States or other countries.    *
 * See the ANSYS, Inc. online documentation or the ANSYS, Inc. *
 * documentation CD or online help for the complete Legal    *
 * Notice.                           *
 * THIS ANSYS SOFTWARE PRODUCT AND PROGRAM DOCUMENTATION    *
 * INCLUDE TRADE SECRETS AND CONFIDENTIAL AND PROPRIETARY    *
 * PRODUCTS OF ANSYS, INC., ITS SUBSIDIARIES, OR LICENSORS.   *
 * The software products and documentation are furnished by   *
 * ANSYS, Inc. or its subsidiaries under a software license   *
 * agreement that contains provisions concerning        *
 * non-disclosure, copying, length and nature of use,      *
 * compliance with exporting laws, warranties, disclaimers,   *
 * limitations of liability, and remedies, and other      *
 * provisions.  The software products and documentation may be *
 * used, disclosed, transferred, or copied only in accordance  *
 * with the terms and conditions of that software license    *
 * agreement.                          *
 * ANSYS, Inc. is a UL registered                *
 * ISO 9001:2015 company.                    *
 * This product is subject to U.S. laws governing export and  *
 * re-export.                          *
 * For U.S. Government users, except as specifically granted  *
 * by the ANSYS, Inc. software license agreement, the use,   *
 * duplication, or disclosure by the United States Government  *
 * is subject to restrictions stated in the ANSYS, Inc.     *
 * software license agreement and FAR 12.212 (for non-DOD    *
 * licenses).                          *
 ***************************************************************   Date: 12/09/2022    Time: 13:00:16 Â
   ___________________________________________________
   |  Livermore Software Technology, LLC       |
   |  7374 Las Positas Road              |
   |  Livermore, CA 94551               |
   |  Tel: (925) 449-2500  Fax: (925) 449-2507    |
   |  www.lstc.com                  |
   |_________________________________________________|
   |  LS-DYNA, A Program for Nonlinear Dynamic    |
   |  Analysis of Structures in Three Dimensions   |
   |  Date   : 08/10/2021   Time: 17:03:01     |
   |  Version : smp s                 |
   |  Revision: R13.0-365-gf8a97bda2a         |
   |  Features enabled in this version:        |
   |   Shared Memory Parallel            |
   |   FFTW (multi-dimensional FFTW Library)     |
   |   Interactive Graphics             |
   |   ANSYSLIC enabled               |
   |   MADYMO indirect coupling (7.2 or higher)   |
   |  Licensed to:                  |
   |  Platform  : WINDOWS X64 (SSE2)         |
   |  OS Level  : Windows 8/10 & Srv 2016/2019 uum  |
   |  Compiler  : Intel Fortran XE 2019 MSVC++ 2019 |
   |  Hostname  : DESKTOP-CFDHIHU          |
   |  Precision  : Single precision (I4R4)      |
   |  Unauthorized use infringes LSTC copyrights   |
 *** License problem ***
 Local license: *** Error Bad license keys!
 *** Error 70022 (OTH+22)
   Please file a Service Request (SR) via the ANSYS Customer
   Portal at https://support.ansys.com.
   Customers using an academic license may seek assistance
   at https://forum.ansys.comE r r o r  t e r m i n a t i o n
December 19, 2022 at 5:09 pm
Reno Genest
Ansys EmployeeÂ
We do not issue node locked licenses anymore; we only issue network licenses. Please set the following environment variable on the client machine:
LSTC_LICENSE=network
The "bad keys in the license file" error message can happen for a few reasons:
- The license file (server_data) was edited in a text editor. This is not allowed. Please make sure you use the original license file sent by Ansys.
- The license file was modified by the email system (this happens!). The solution is to request that the LSTC license file is sent via Ansys SecureTransfer.
- You have a license file with "Jobs" and "Added cores" which requires the latest LSTC license manager.
- The license is used as "node locked".
You can download the latest version of the LSTC License Manager here:
https://ftp.lstc.com/user/Download-Instructions/Job-License-Manager/
username: user
password: computer
Here is the LSTC license manager installation procedure for Windows:
https://ftp.lstc.com/user/license/License-Manager/LS-DYNA%20Win%20License%20Server%20installation%20and%20update%20Aug%2026_2.pdf
Here it is for Linux:
https://ftp.lstc.com/user/download-instructions/License-Manager/LSTC_LicenseManager-InstallationGuide.pdf
Finally, the following website will have most of the LS-DYNA resources:
https://lsdyna.ansys.com/
Let me know how it goes.
Reno.
- The topic ‘Challenges with Node-Locked License in Win 10’ is closed to new replies.
3772
1358
1173
1090
1014
