November 8, 2018 at 2:35 pm
senthilathiban
SubscriberHi all,Â
I have done a simulation in RANS and LES using ANSYS Fluent 18.0 and compared with experimental results. The RANS results seems good, while the LES results are unacceptable. Please see the attached pdf. Any help to rectify the error is appreciated.Â
Thanks,
senthil.Â
November 8, 2018 at 3:06 pm
Forum ModeratorAs staff we're unable to open attachments, so I've not looked at the results.Â
Have you used a suitable mesh and time step in the LES calculation? Did both models converge to a good level? Is the experimental data good (always worth checking)?Â
November 8, 2018 at 3:12 pm
senthilathiban
computational domain.
LES.. time averaged at 65 sec.Â
The above image shows a velocity probe near the point (0.6,0.2,0.34), 0.6 m distance from the inlet. As it can be seen that the velocity converges nearly to 0.225 m/s which equals the inlet velocity. There is no reduction in the velocity throughout the flow and as the period of simulation increases, the time averaged velocity also increases. This is the main problem in LES simulation.
The mesh is fine. The experimental results have been validated by many researchers in RANS simulations. I am trying to validate it in LES.
November 8, 2018 at 4:03 pm
Forum ModeratorHave you got the same plot from the RANS model? Please can you also post the residual plots.Â
November 9, 2018 at 8:37 am
November 12, 2018 at 6:40 am
seeta gunti
Ansys EmployeeHello,
Did you use the same mesh for RANS and LES?Â
What kind of LES model did you use? I guess it is a confined flow. If it so, you can use either Dynamic LES or WMLES model and mesh needs to be very very fine.
How did you do the sampling? We have some best practices to run LES model. WE have few tutorials on LES. Please go through the below tutorials.
https://www.youtube.com/watch?v=iELFWDuSoe4
https://www.youtube.com/watch?v=ky7lGjmVqM8
Seeta
November 12, 2018 at 7:06 am
Keyur Kanade
Ansys EmployeeAs mentioned earlier, the mesh and time step are important factors here.Â
Can you please insert some images for mesh used.Â
November 12, 2018 at 7:26 am
DrAmine
Ansys EmployeeI want first of all recommend having a look into the Best Practice Document for Scale Resolving Simulations. Parts of it could be find in the CFX Best Practice Documentation.
November 12, 2018 at 9:51 am
November 12, 2018 at 10:54 am
DrAmine
Ansys EmployeeAgain I recommend going through the SRS guidance. Temporal and spatial resolution for LES are by fore more strict then the ones for RANS.
- The topic ‘Challenges in LES Simulation.’ is closed to new replies.
