November 25, 2020 at 11:20 am
sam.3.r
SubscriberI have 3 inlet fans spinning at 1500 RPM ( =25 Rounds Per Seconds )
Pushing 250 [m^3/h] { 250/(60*60) *1.204 ~ 0.084 kg/s }
"1.204 is the air dencity at 20 degrees C"
I have 3 Coordinate systems, one for each fan!
I just want to understand what values are required for:
Axial component
Radial Component
Theta Component
Is axial the velocity of the outer edge of the fan?
Radial should be 0
Theta is radians per second for the outer edge of the fan?
Thank you in advance :)
November 25, 2020 at 12:24 pmNovember 25, 2020 at 1:50 pmAmine Ben Hadj Ali
Ansys EmployeeIf you have already defined your local coordinate systems why not directly using them in the boundary specification?nNovember 25, 2020 at 2:03 pmsam.3.r
SubscriberIf you have already defined your local coordinate systems why not directly using them in the boundary specification?/forum/discussion/comment/98365#Comment_98365
No idea what you mean !nI want to know:nn' Axial componentnRadial ComponentnTheta ComponentnIs axial the velocity of the outer edge of the fan?nRadial should be 0nTheta is radians per second for the outer edge of the fan? 'nnandnn' Also what isninlet 1.1ninlet 1.2ninlet 1.3nis it:ninlet 1.1 = xninlet 1.2 = yninlet 1.3 = z 'nnEdit*nI can not find a single place on the internet that talks about those! nNovember 25, 2020 at 4:05 pmAmine Ben Hadj Ali
Ansys Employee1.3 will correspond to the local z axis. So that will be your local axis of rotation.nNovember 25, 2020 at 7:49 pmsam.3.r
Subscriber1.3 will correspond to the "local z" axis. So that will be your local axis of rotation./forum/discussion/comment/98399#Comment_98399
thank you, now I have one question answered !nOne to go!nNovember 27, 2020 at 9:05 amsam.3.r
SubscriberBump
n
November 27, 2020 at 11:57 amAmine Ben Hadj Ali
Ansys EmployeeTheta Velocity Component is the velocity component in circumferential direction and this is meter per second: Velocity dimension.nDecember 1, 2020 at 2:09 amsam.3.r
SubscriberTheta Velocity Component is the velocity component in circumferential direction and this is meter per second: Velocity dimension./forum/discussion/comment/98558#Comment_98558
that's the Axial component! nif not then the axial and theta is the same!!!nDecember 1, 2020 at 7:45 amAmine Ben Hadj Ali
Ansys Employee/forum/discussion/comment/98558#Comment_98558that's the Axial component! if not then the axial and theta is the same!!!/forum/discussion/comment/98858#Comment_98858
?nViewing 9 reply threads- The topic ‘[CFX][Setup] Cyl. Vel. Components’ is closed to new replies.
4633
1535
1386
1225
