TAGGED: ansys-cfx, cfx-pre, cfx-setup, cfx-solver, fatal-error
December 21, 2024 at 7:15 pm
Ozge_Tuna_
SubscriberI am encountering a persistent issue when attempting to launch the Setup section in ANSYS Workbench for a Fluid Flow (CFX) analysis. The application crashes with the following errors:
socketError: RemoteEngineProtocol::receiveTransStat - Communications error: unexpected end of transmission from engine, expected status code.EVP_DecryptInit: Could not load the shared library.ÂI am using Workbench 2024R2 Student's version.ÂAny insights or suggestions would be greatly appreciated. -
December 23, 2024 at 1:46 pm
V.P
Ansys EmployeeHi Ozge,
Solution 1:
Rename .cfx folder in user profile.
Solution 2:
Rename libcrypto-1_1-x64.dll and libssl-1_1-x64.dll to libcrypto-1_1-x64.dll.backup
libssl-1_1-x64.dll.backup in C:/Windows/System32Â
February 19, 2025 at 4:03 pm
Johnson Liao
Subscriberfor same problem, it was happened in v251 when launching FLUENT and ENSIGHTÂ at least. So, what is correct procedure to correct it?
regs,
Johnson
1494
1376
1209
