May 6, 2025 at 2:31 pm
businessyoussefm
SubscriberI have been trying to fix this error for 2 days but can't figure it out I uninstalled and installed ansys 3 times but no luck, tried deleting the .cfx folder, and .ansys files but nothing seems to work, I'm trying to open results in CFX from the WB, but it keeps popping the error, the standalone version works if I lauch it outside of WB but anything CFX related inside WB doesn't work. Error:
System.ApplicationException: Application failed to connect.
  at Ansys.CFX.Foundation.App.CUEApplicationProxy.Start(Boolean waitForCommands)
  at Ansys.CFX.CFXCore.App.CFXPreProxy.LoadApplication()
  at Ansys.CFX.Foundation.Data.CUESourceDataObject.Edit(IFullContext context, Boolean interactive)
  at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext(CommandContext subContext, IExecutionEngineCallback tracer)
  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute(IExecutionEngineCallback executionEngine, CommandContext subContext)
  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute(IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions)
--- Ansys.Core.Commands.CommandFailedException: Application failed to connect.
CommandName: CFX.EditSetup(Container="Setup 2")
  at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException(Exception e)
  at Ansys.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext)
  at Ansys.CFX.CFXCore.Commands.EditSetupCommand.InvokeAndWait(IProtectedContext context, DataContainerReference Container, Boolean Interactive)
  at Ansys.CFX.CFXCore.Commands.EditSetupGui.Invoke(GuiOperationContext context)
  at Ansys.UI.GuiOperationContext.Invoke(GuiOperationMetaData operationData)
  at Ansys.UI.UIManager.InvokeOperationCore(String pseudoname, OperationDelegate callback, Boolean allowOSMessages, Boolean coreTransaction, Boolean deferredRefreshOnly) -
May 7, 2025 at 12:14 pm
CFD_Friend
Ansys EmployeeHiÂ
Suggested Solution:
Check for the following files in the system directory:
C:\Windows\System32\libcrypto-1_1-x64.dll
C:\Windows\System32\libssl-1_1-x64.dll
If these files exist, rename them to:
C:\Windows\System32\libcrypto-1_1-x64.dll.safe
C:\Windows\System32\libssl-1_1-x64.dll.safe
After renaming the files, try launching CFX again.
- acces to path ‘session_files’ is denied error
- unexpected license problem; exiting. hit return to exit.
- critical error during installation of 24 R2 version
- No FlexNet Publisher (FNP) license found for feature HPC Parallel.
- Ansys Electronics Desktop crashes when trying to set the steel type in RMXprt
- Can not find Spaceclaim option in ANSYS2024R2 workbench
3044
971
863
858
792
