May 23, 2024 at 4:13 am
Sneha E S
SubscriberI want to analyse an RCC beam wrapped with a CFRP sheet of 0.34mm thickness, what is the connection needed to be provided between concrete and CFRP sheet.
May 25, 2024 at 3:26 pm
dlooman
Ansys EmployeeIn APDL you could mesh the surface of the RCC elements with shells using the ESURF command. The shells would share nodes with the solid elements so would be fully connected. Typical commands would be:
nsel,s,ext  ! select the nodes on the exterior of the RCC elements
type,2Â Â Â Â ! shell type number
secnum,2Â Â Â ! shell thickness number
mat,2Â Â Â Â Â Â ! shell modulus number
esurf     ! create shell element with the selected nodes
allselÂ
- The topic ‘CFRP wrapped RCC beam’ is closed to new replies.
