CFL number – pressure based solver fluent
    • manelaero2020
      Hi friends ;
      How can we control CFL number when we use a pressure-based solver in Fluent?
      I can't find it in the solver controls
      Thank you ?
      If you've got pseudo transient option on it's the time scale factor. Otherwise you adjust the time step. Without knowing if you're running transient or steady I can't say which to look at.
    • manelaero2020
      Ok thank you, Rob, I am running a steady computation so I think it isn't possible to adjust the CFL number because the physics is established, and no longer depends on the time
    • Amine Ben Hadj Ali
      There is some CFL number based under relaxation used by coupled solvers ( pressure and density based steady and unsteady) which does not really have anything to do with the transient CFL number we usually learn in the CFD lectures
    • manelaero2020
      Does the user can modify this parameter in that case? If yes, what do you think about the impact on the computation?
      In which case? I will not change default values as a beginner. For steady state problems use pseudo transient coupled solver
      Default Courant Number is 200 in steady, try using 25-50 if the solution isn't converging. It'll mean you need more iterations to reach convergence, but you've a better chance of getting there. For pseudo transient, the time scale factor is 1, dropping that to 0.1 can help stabilise the solution.
Viewing 6 reply threads
  • The topic ‘CFL number – pressure based solver fluent’ is closed to new replies.
