TAGGED: compressible-flow, gauge-pressure, jet, nozzle-jet, swirl-flow, turbulence
March 10, 2026 at 6:57 pm
fatemeh.hosseini1992
SubscriberHello everyone,
I am currently simulating a jet milling process. The system consists of a cylindrical chamber with six nozzles. Air enters through the nozzles at a velocity of 200 m/s, creating a strong circulating flow inside the chamber due to the cylindrical geometry. The gas then exits from the bottom outlet of the chamber. I am using the k-ε turbulence model (at this stage I have not added particles yet; I am only simulating the gas phase).
My current setup is as follows:
Gravity: Off
Gas model: Ideal gas law
Inlet boundary condition: Velocity inlet (200 m/s at the nozzles)
Outlet boundary condition: Pressure outlet
The problem I am facing is that a region of negative static pressure appears inside the chamber, particularly near the outlet
A similar geometry has been attached for reference; it is not my exact geometry, but it is quite similar.I would really appreciate any suggestions or insights regarding this type of flow behavior in jet mill simulations.
March 11, 2026 at 10:01 am
Forum ModeratorPlease post some images, pressure along with tangential velocity & axial velocity across the centre yz plane. I suspect I know what's happening but am supposed to use your images to answer questions on here.Â
Which turbulence model are you using, and how are you planning on including the particles?
5639
1885
1403
1298
