TAGGED: ansys-cfx, ansys-fluent, cfd-analysis, error, warnings
November 19, 2024 at 6:55 am
November 19, 2024 at 11:12 am
Forum ModeratorIt's a warning, so needs to be understood and then potentially ignored. In this this if the whole domain is spinning about z-axis the chevrons are moving tangentially at around 90 degrees to the forced flow path. Pump models can produce the same warning as the impellor is spinning.Â
