October 26, 2023 at 9:08 am
bilal ojaily
SubscriberHello!
I am working on CFD for simulation a fan inside a pipe, but I dont want to rotation the fluid direction, I have just wanted to rotate the fan, how can I do it ?
1) Should I suppress the fan ?, if I dont suppress the fan in meshing may I have a problems because of the fan and the enclosure will be on top of each other
2) in Setup > Boundary Conditions > fan (intake-fan), Should I use it ?
Thank you so muvh, have a nice day
Bilal. -
October 26, 2023 at 10:24 am
geetanjali.alle
SubscriberThese might help. I usually supress the fan but I did not face any issue even I don't. I use the mesh motion option under cell zone conditons. Haven't tried the fan option.
https://www.youtube.com/watch?v=p0Ubyt4sWA0&ab_channel=cfdengineer
https://youtu.be/hyKoRia3Ows?si=fcQbXcwO_JYsOqbP
October 26, 2023 at 11:10 am
bilal ojaily
SubscriberThank you Geetanjali
Actually I watched before the second video, I did not notice fan motion, I think it was fixed and the fluid is movable
Thanks a lot Ms. AlleÂ
- The topic ‘CFD rotation fan’ is closed to new replies.
5824
