July 28, 2021 at 4:12 pm
PhilippM
Subscriberhello all,
I am trying to investigate the hydromechanical properties of joints as part of a lecture at university. Im using Ansys student 2021 R1.
I have simplified this problem by using a measuring cylinder with an open outlet (in the form of a joint)Â at the bottom. In Ansys I have used the system "Fluid dynamic (Fluent)". However, at the end of the simulation I cannot open my results in "CFD Post Processing". I get the following error messages (a screenshot is in the attachment):
- Error reading file XXXXX.dat.h5'
- Error opening file XXXXX.cas'
- The results reader couldn´t be initializedÂ
Does someone have an idea how I can fix this and display my results ? Thank you for your efforts!
Best,
Philipp
July 29, 2021 at 12:14 pmKeyur Kanade
Ansys EmployeeAs ANSYS Staff, we can not download attachments. Please upload images using upload image functionality.
Please export .cdat file from Fluent and then read it in CFD-Post.
Or you can use write .cas and .dat files from Fluent to read them in CFD-Post.
Regards Keyur
How to show full resolution image
How to use Google to search within Ansys Student Community
July 29, 2021 at 12:36 pmPhilippM
SubscriberHallo Keyur,
ty for your fast replay. I already tried to input the result files by hand by using the "load Results" button in CFD-Post and choose the result data file. But it still shows me the same error message. I┬┤ll put you an image of the error type in here. Ty for your help!
regards,
Philipp
April 6, 2022 at 4:01 pmOlnjiko
SubscriberI have the same issue.
July 12, 2022 at 9:13 ama1055246
SubscriberI have the same issue. Has anyone solved it please?
Viewing 4 reply threads- The topic ‘CFD Post processing error’ is closed to new replies.
6765
1330
1097
