September 10, 2020 at 2:46 pm
JASOMCHANG
SubscriberHello everyone, I have some problems in CFD post-processing. The following figure shows the result of the calculation?Calculated result This is at timestep 19
September 10, 2020 at 3:36 pmSurya Deb
Ansys EmployeeHello, nCan you please check the Scales on the Contour. The 1st contour has different scales than the 2nd and the 3rd. nIf so, then please change the scale accordingly. The 1st and the 3rd should have same/similar scales.nRegards,nSuryanSeptember 10, 2020 at 4:03 pmSeptember 10, 2020 at 4:41 pmSurya Deb
Ansys EmployeeCan you please change from Global to Local Range and check it ?nSeptember 11, 2020 at 1:44 amJASOMCHANG
SubscriberThank you, the problem is solvednnViewing 4 reply threads- The topic ‘CFD post-processing’ is closed to new replies.
4934
1638
1386
1242
