May 21, 2023 at 4:55 pm
May 23, 2023 at 12:00 pm
Rahul Mule
Ansys EmployeeHi
Please select 'variable' mode and color it with 'Pressure' to plot the pressure contour.
You can also refer to CFD-Post Tutorials (ansys.com).
Rahul
Fluids Engineering Courses | Ansys Innovation Courses
May 23, 2023 at 4:07 pm
NickFL
SubscriberTry turning off the Plane Bounds which you have set to Circular (i.e. Set type to NONE). Does this show your plane? Now if you want to you can again clip the plane using circular, but make sure the value you specify is appropriate.
- The topic ‘CFD-Post Plane doesn’t appear’ is closed to new replies.
1587
1386
1242
