CFD post initializing error
    • YMAkib
      I can't open my CFD post-processing because it is showing an error loading results state. When I am using fluent, sometimes it shows acquiring a license but I already have a license. I am adding a screenshot of the problem.
      I think you're missing the results - check the warning in Line 5 of the messages. Open Solution & run an iteration and I suspect Post will work (but you still won't have any results).
    • YMAkib
      I have not run the full calculation, stopped in the midway after the end of some iteration. The problem is solved for now as I have moved my data to another CFD post-processing option. Don't know what's the main reason for the problem.
    • chiêu nguyễn
      hiện tại tôi cũng đang gặp phải vấn đề này ,bạn có thể hướng dẫn cho mình cách giải quyết vấn đề trên được không ạ.
      The recommended workflow was changed to do the post processing in Fluent in about 2019R1, assuming you're using the current software I'd be doing that. Unless there's a good reason not to?
Viewing 4 reply threads
  • The topic ‘CFD post initializing error’ is closed to new replies.
