CFD Post function calculator in a solid domain
    • Scott Ormiston
      We are trying to do the area integration of the heat flux on a plan in a solid domain in a conjugate heat transfer problem.
      This does not work because the function calculator is selecting the fluid domain and will not allow us to change it.
      How can we do this calculation in the solid domain?
    • Scott Ormiston
      I meant to say "plane" instead of "plan".
    • Surya Deb
      Can you create a User Surface along the plane of interest and then try using the calculator?
      Regards SD
    • Scott Ormiston
      We made a plane in the solid domain and asked for areaInt of the wall heat flux (heat flux did not work) over the plane.
      The answer is wrong because the domain is the fluid. Please see the attached screenshot.
  • The topic ‘CFD Post function calculator in a solid domain’ is closed to new replies.
