February 20, 2024 at 8:02 pm
Reza Khoshbakht
SubscriberI attempted to simulate a rotational cylinder, but I encountered an issue when trying to open the result section. The error message I received is:
socketError: RemoteEngineProtocol::receiveTransStat - Communications error: unexpected end of transmission from engine, expected status code.
Does anyone have any insights on how to resolve this? Thank you.
February 23, 2024 at 12:45 pm
Essence
Ansys EmployeeHello,
Are you able to open the Fluent post-processing without any problem?
February 23, 2024 at 2:26 pm
Reza Khoshbakht
SubscriberNo, actually, when the solution part is completed and I attempt to open the results section, I encounter the aforementioned error
February 26, 2024 at 3:07 pm
CAP_NJ
SubscriberAs a workaround: try to export your solution from fluent in e.g. POST format and then read in in POST. So, everything without connecting the modules.
- The topic ‘CFD-Post error’ is closed to new replies.
