CFD-post application failing to connect
    • Nabaraj
      I am using Ansys Fluent 18.1 Student version. It was running all good earlier. But now when I try to open "Results" for post-processing in workbench , the following error message pops up. Anybody have idea what is wrong and hot to fix it?
      System.ApplicationException: Application failed to connect.
         at Ansys.CFX.Foundation.App.CUEApplicationProxy.Start(Boolean waitForCommands)
         at Ansys.CFX.CFDPost.App.CFDPostProxy.LoadApplication()
         at Ansys.CFX.Foundation.Data.CUESourceDataObject.Edit(IFullContext context, Boolean interactive)
         at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext(CommandContext subContext, IExecutionEngineCallback tracer)
         at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute(IExecutionEngineCallback executionEngine, CommandContext subContext)
         at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute(IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions)
      --- Ansys.Core.Commands.CommandFailedException: Application failed to connect.
      CommandName: CFX.EditResultsAnalysis(Container="Results")
         at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException(Exception e)
         at Ansys.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext)
         at Ansys.CFX.CFDPost.Commands.EditResultsAnalysisCommand.InvokeAndWait(IProtectedContext context, DataContainerReference Container, Boolean Interactive)
         at Ansys.CFX.CFDPost.Commands.EditResultsAnalysisGui.Invoke(GuiOperationContext context)
         at Ansys.UI.GuiOperationContext.Invoke(GuiOperationMetaData operationData)
         at Ansys.UI.UIManager.InvokeOperationCore(String pseudoname, OperationDelegate callback, Boolean allowOSMessages, Boolean coreTransaction)
      Thanks in advance.
    • vganore
      Could you please try clearing data from Results component?
    • Nabaraj
      Hi vganore,
      Thanks for the quick reply.
      Clearing data from Results component did not help either.
      Workbench also pops up the same error on refreshing the "Results" component.
      Thanks.
    • vganore
      Take another result component in workbench from component system and connect your solution cell with new results component. See if that helps.
      If same problem persists then try opening CFX in a standalone mode through windows start menu. See if it gives same error. Might be a license issue.
    • Nabaraj
      Thanks vganore for the suggestion.
      New linked results had similar error. CFX standalone mode had error too. May be the license issue like you suggested.
      I had another fresh installation of Ansys 18.2 and all is good now.
      Many thanks for your response.
    • tjzhgs
      I have the same issue when I use 19.2 student version. Could you please tell me how you figure out your problem?  Your suggestion is useful to me. Thank you!
    • A.Azimi
      Have you found any solution for this issue?
      Shahab
      You're better off logging a new question in Installation, that way we can check if it's the same problem.
    • anandhu_suresh
      iam experiencing same issue with 2020R2 Student version.I tried re-installing multiple times still issue persisit.
      When clicking on results its showing application failed to connect.
      Please help!!
    • sp_ef
      I am experiencing the same issue! It would be much appreciated if anyone could help with the issue!
      Spyros
      I'll refer you to my previous comment, and lock this thread.
Viewing 10 reply threads
  • The topic ‘CFD-post application failing to connect’ is closed to new replies.
