CFD-Post Application Error
    • slong
      I am trying to view the results for a simulation of a coiled heat exchanger. The simulation successfully ran but when I try and open the results in CFD-Post, I receive the following error.
      "CFD-Post Application Error
      ERROR
      Failed to make geometry for domain 'Default Domain'"
      I can't seem to find any relevant information online so any help would be appreciated.
      Which solver did you run the model with?
    • slong
      I used CFX.
      OK, one for I suspect. Did the solve complete without any errors?
    • slong
      The solve did complete without any errors. It was not until I attempted to generate results that I go the error. I did figure out a fix for the issue though. There are two coils in the heat exchanger that are isolated from each other, but I had considered the fluid in each as one domain. Once I went and separated them into two different fluid domains, the issue went away.
    • DrAmine
      Good idea aad actually the best to consider both as separate domains.
      Regarding the error you saw in CFD-Post: which version are you using?
    • slong
      The ANSYS version I have is 17.2.
Viewing 6 reply threads
  • The topic ‘CFD-Post Application Error’ is closed to new replies.
