TAGGED: 2-fsi, 2-way-coupled-fsi, ansys-result-view, post-cfd
August 12, 2024 at 4:10 pm
Xbuddyin
SubscriberHello everyone,
I’m currently working on a Fluid-Structure Interaction (FSI) analysis using system coupling in ANSYS Workbench. The simulation involves both ANSYS Fluent (for the fluid domain) and ANSYS Mechanical (for the structural domain). The analysis is running fine, and I can see the results separately for each domain in seperate results. I’m unable to see any combined results that reflect both the fluid and structural interaction (like animation).
Is there a specific procedure or setting I need to follow in CFD-Post to visualize the combined deformation of the structure along with the fluid flow fields? Any tips on how to correctly post-process these coupled results would be greatly appreciated.
August 13, 2024 at 10:03 am
Petros
Ansys EmployeeHi,
From 2021R1 onwards results from Mechanical can not be loaded into CFD-Post. You can either view them separately or do a combined post-processing in EnSight.
5954
1307
