July 5, 2023 at 2:26 pm
Marius Carrier
SubscriberI'm using fluent with out the workbench. Now that I'm finished with my simulations I have trouble opening my case and data in CFD-Post, I tried lodaing it into workbench but that doesn't work because the data is so big that the solution times out before it finishes and so I can't open post there. How do I import my data and case into cfd-post without workbench?
thanks for the anwser
July 6, 2023 at 9:59 am
SRP
Ansys EmployeeHi,
I suggest you to check fluent user's guide: 3.14. Exporting Solution Data after a Calculation (ansys.com)
This helps you to understand how to export the files.
Thank you.
- The topic ‘CFD-POST’ is closed to new replies.
