March 18, 2024 at 6:21 am
Ammar Ahmed
SubscriberHello everyone,Â
I am trying to simulate a tank filled 90% with fluid (lets say water) and is pressurized by nitrogen gas in the 10% volume availabe in tank. I am confused as to which physical model should i use to simulate this as my main aim is to see pressures achived at outlet. The nitrogen is maintained at 230 bars and water is supposed to be maintained at 60 bars so thatr at outlet i can get 60 bar with 3kg/s flow rate. the inlet and outlet dias are 25.4 mm. I have a pipe attached at outlet as shown below
March 18, 2024 at 10:28 am
Forum ModeratorOK, have a look at the various options in Fluent. Gas can be compressible, so that's not a problem. But.... If you already know the pressure and flowrate, what are you trying to find out from the model?Â
March 19, 2024 at 7:21 am
Ammar Ahmed
SubscriberThe aim is to find out inlet conditions at which i can have a specific mass flowrate and pressure of water at outlet of pipe and what is the expected pressure drop.
March 19, 2024 at 11:19 am
Forum ModeratorSo you don't need the free surface? Water isn't compressible (well mostly it isn't) so you can push the desired mass flow though the system and find the pressure loss.
March 21, 2024 at 6:54 am
Ammar Ahmed
SubscriberSorry didnt understand your point can you please elaborate.
March 21, 2024 at 11:54 am
Forum ModeratorPart of the CFD modelling process is working out what you actually need in the model. In your case, if you want to know the tank pressure to get a set mass flow, and given water is incompressible, how much do you really need to include?
March 22, 2024 at 6:15 am
Ammar Ahmed
SubscriberThankyou for your help I just have one more question.
So i performed cfd with different inlet speed and i got my desired inlet and outlet mass flowrate but the static pressure at inlet and outlet is 33 MPa and 10 MPa. How can I calculate the pressure drop theoratically and from CFD? Is the difference of static pressure at inlet and outlet the pressure drop?
March 22, 2024 at 9:48 am
Forum ModeratorInlet P - Outlet P = dP. It really is that simple for incompressible fluids; just watch you're comparing like for like pressure.Â
March 25, 2024 at 4:18 am
Ammar Ahmed
SubscriberGreat Thanks
- The topic ‘CFD of pressurized fluid with gas in a tank’ is closed to new replies.
- affinity not set
- Continuing SAG Mill Simulation with New Particle Batch in Rocky
4492
1494
1376
1209
