September 2, 2025 at 2:19 am
jijojose2024
SubscriberHow can i simulate the air flowing into a vacuum tank where inside the tank presssure is close to vacuum and outside is ambient pressure
September 2, 2025 at 7:49 am
Essence
Ansys EmployeeHello,
You can patch the pressure value near to vacuum pressure, then apply all the other quantities like velocity, turbulence quantities near to zero. And then apply the inlet BC as per convenience. It can be mass flow inlet, velocity inlet or even the pressure inlet.
Ansys Innovation Space
1389
1188
1100
1015
