February 27, 2023 at 6:34 pm
Vicky
SubscriberDear Sirs,
I am trying to simulate a two-phase flow in a horizontal pipe (air + solid particles), coupling Fluent software with Rocky software. It started with good results, but When the particle is 1 meter away from the starting point, it started to give me this type of message:
Please can you help me solve the problem why the particles are re-entering the CFD domain?
Thank you.
February 28, 2023 at 11:10 am
Forum ModeratorWhat do the two domains look like? Overlap generally means you're trying to add a new particle where an old one is already present (it's a Rocky solver check).
February 28, 2023 at 5:41 pm
March 1, 2023 at 9:42 am
Forum ModeratorCheck the inlet region: can you get the particle flow rate into the domain through the area you've set? Remember there's a packing limit as DEM particles in Rocky occupy a finite volume.
March 1, 2023 at 4:25 pm
Amirhossein Fardi
SubscriberWhat is your version of Ansys and Rocky ? I had same error in Version 2022.2 while everything ok in 2022.1
March 7, 2023 at 10:09 pm
Vicky
SubscriberHello, my version of Rocky is 2022.1 too.
Regarding my mass flow rate, it is 0.00351kg/s and the pipe diameter is 30.5mm
March 8, 2023 at 5:59 am
Amirhossein Fardi
Subscriberyou have two diameter. pipe diameter and cfd domain diameter. check the length and diameter of both geometries and sure both size are same.
- The topic ‘CFD-DEM Fluent – Rocky’ is closed to new replies.
5654
1890
1414
1304
