CFD-DEM error
    • fatemeh.hosseini
      Hello every body,
      I coupled EDEM and Fluent together. It initially performed well. The error happened after 11400 iterations:
      59: MPT_host_to_node_char: error: Failed to allocate 333031200 bytes (..\..\src\locate_particles.c:159)!: Not enough space
      Fatal error in PMPI_Bcast: Invalid buffer pointer, error stack:
      PMPI_Bcast(2667): MPI_Bcast(buf=0000000000000000, count=333031200, MPI_CHAR, root=0, comm=0x84000002) failed
      PMPI_Bcast(2636): Null buffer pointer
      [mpiexec@UL-4XJFH73] ..\hydra\utils\sock\sock.c (420): write error (Unknown error)
      send of 23 bytes failed.
      [mpiexec@UL-4XJFH73] ..\hydra\utils\launch\launch.c (121): shutdown failed, sock 644, error 10093
      The fl process could not be started.
      (Please refer to the attached file)
      The simulation is located in the 167 gigabyte-free deive D.
      I used 80 of the system's 96 cores for simulation.
      Could you please guide me in this field?
      Fatemeh
      Are you using the EDEM coupling UDFs?  The error suggests you've run out of RAM rather than disc space.
  • The topic ‘CFD-DEM error’ is closed to new replies.
