3D Design
3D Design
CFD Capability to do analysis with time step
    • satishbshenkar
      Currently, we did many analysis in CFD with continuous flow as input and measuring delta P across the pipe. However, now we would like to understand how much fluid can raise with input velocity truncated with time step.
      For example; If I apply fluid with V = 1m/s in simple tube now after 1mSec I would like to understand how is fluid level raised. Let me know if this analysis is feasible in ADL or not.
      Please reply asap if anyone knows the answer.
      Satish
    • subashni.satish
      Hello Satish Shenkar
      You can set the simulation end time as shown in the image below.
      You can also monitor the time for which the solution has been solved on the contour table, (refer below image).
      I hope this is what you were looking for.
  • The topic ‘CFD Capability to do analysis with time step’ is closed to new replies.
