April 2, 2024 at 6:05 am
RAJ ARUMUGAM
SubscriberSpecifications for analysis;
Inlet BC : 374000kg/hr
Inlet Temp: 196deg C
Outlet  Pressure  : 0.07 kg/cm2 (g)
Fluid :Flue gas
Analysis using Ansys software I WANT RESULR FOR THIS PARAMETERÂ TO FINDÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â
Inlet mass flow should be equally distributed to all 4 outlets
Firstly run analysis and study the flow distribution across each outletSecoundary objective:
Calculate Pressure drop -
April 2, 2024 at 1:34 pm
Forum ModeratorYes, looks a decent starting point. What level of heat loss are you expecting?Â
- The topic ‘CFD ANALYSIS FOR FLUE GAS PASSED THROUGH TO THE DUCT’ is closed to new replies.
