April 5, 2022 at 7:58 pm
mohammed_mostafa
SubscriberI am doing a CFD simulation of injected air through a tank filled with water. I want to ask if I can through ansys to determine the number of bubbles formed through the simulation and the mean diameter of them.
April 6, 2022 at 8:18 amNikhil N
SubscriberHello,
It is very much possible to model the air injection and subsequent bubble formation Using Ansys FluentÔÇÖs volume of fluid (VOF) multiphase modeling capability. However, caution needs to be taken while discretizing the domain and setting up the solver to capture the flow accurately. To find out the number and the mean diameter of bubbles, you need to try things out at the post-processing stage.
To understand more on how to setup a case, please refer to this link: Chapter 19: Using the VOF Model (ansys.com)
Note that, the tutorial in the link is just for the reference. If you are not able to access the above link, please refer to this forum discussion: Using Help with links ÔÇö Ansys Learning Forum
Nikhil
April 6, 2022 at 2:06 pmmohammed_mostafa
SubscriberThanks for answering. I have already done the simulation of air injection and it worked, but I want to know how to extract the information I want as number of bubbles and their mean diameter.
April 14, 2022 at 12:28 pmRob
Forum ModeratorWhich model did you use?
Viewing 3 reply threads- The topic ‘CFD air bubbles simulations’ is closed to new replies.
3572
1193
1076
1063
952
