3D Design
3D Design
Centrfugal pump preprocessing
    • lokeshk
      I have a solid 3D solid cad model of centrifugal pump that includes both impeller and volute. How should preprocessing be done in ansys spaceclaim 2024R2 to take this cleanup model to the ansys fluent to do the MRF approach sinulations? Give me the step-by-step exact approach for both impeller and volute to create the fluid domain Can you please explain in details only for the fluid flow analysis with no CHT can anyone Give me a detailed explanation for how to do the preprocessing
      Read this Ansys Help page: https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/corp/v251/en/flu_th/flu_th_sec_mrf.html
      The basic steps in SpaceClaim are to hide the Impeller and on the Prepare tab, use the Volume Extract button to create the volume body inside the volute. Turn on the impeller and on the Design tab, use the Combine tool subtract the impeller from the volume body to get the total fluid volume. Note that by default the interference solid (identical to the impeller) is created so you must delete that to end up with just two bodies to transfer to Fluent.
      Construct surfaces to split the total fluid volume into two pieces near the half-way point between the outer faces of the impeller and the inside faces of the volute.  Now you have the rotating fluid body and the stationary fluid body.
    • lokeshk
      What should I do if both impeller and volute fluid domains are overlapped with each other?
      If the impeller can rotate, it does not overlap with the volute. Please reply with an image of a cross-section through the axis to show the impeller and volute.
    • lokeshk
      Thanks for the reply. Kindly review the section view
    • lokeshk
      In practical there is no overlap. However once after creating the enclosure region there is a overlap between impeller enclosure and volute fluid domain.
      Construct a solid body by revolving the orange lines below about the axis to divide the total fluid volume into two pieces near the half-way point between the outer faces of the impeller and the inside faces of the volute.  Now you have the rotating fluid body and the stationary fluid body.
    • lokeshk
      Thanks for the guidance. I have followed your instructions and created the reference solid body for the impeller and extracted the fluid volume without the impeller. Can you help me with the next step? I have attached the reference image
    • lokeshk
      It will be easier for me to help if you reply with a link to the .scdoc file in your Google Drive or other online file sharing site such as OneDrive or Jumpshare.  If using Google Drive, create the link so that anyone with the link can download the file.
    • lokeshk
      Hello Sir. Kindly use this link to access the model   https://drive.google.com/drive/folders/15IDQtfsxN8lz7r-m5JoRr8GDQiKUFTSv?usp=drive_link
      Hello Lokesh,
      I looked at your geometry and note there is a missing part. The impeller and volute show the inlet and outlet.
      But on the back side of this image, there is a missing cover that closes the back of the volute. Please add that part. I don’t know how close it comes to the impeller.
      In the cross-section below, you can see how the missing part is needed to define a stationary wall on the fluid volume.
      In orange is the casing spacer ring. In reality you need clearance to allow rotation but no significant airflow passes through that gap and you will get a better mesh if you make the spacer ring ID the same diameter as the impeller hub.
      Now you will create the rotating fluid body at the surfaces created by rotation of the orange lines.
      Another simplification to the mesh is in the gap above the ring which could be deleted.
      Making those changes, it makes sense to merge the ring into the volute solid body. I also deleted the big hole in the volute where the cover would be bolted in and get this assembly.
      Here is the final result after pulling the impeller bottom face down 1 mm and fixing a 0.05 mm step in the volute cover.
    • lokeshk
      If I close the gaps, how can I create the fluid domain?
    • lokeshk
      If possible, can you share the cleaned model with fluid extraction for both impeller and volute
      I recommend another simplification as shown below.
      Here is one cross-section.
      Here is the 3D view of the rotating fluid volume in green and the static fluid volume in purple.
      Here is an Ansys Mesh with default settings except for adding a Patch Conforming tetrahedrons method.
    • lokeshk
      Could you please share me the file with me ..?cleaned up model is more than sufficient
    • lokeshk
      It seems this is pretty much new approach which you followed.Thos is not the approach I used to create the fluid domain.
      I am not an expert at CFD. A better mesh might be found by using Fluent with Fluent Meshing. I didn't yet include any inflation layers. However clean geometry is required for getting an acceptable mesh. Please tell me the approach you used to create the fluid domain.
    • lokeshk
      I have shared one file with you right in that way .I have selected all the external faces of volute and using volume extraction feature ihace created the stationary fluid domain
    • lokeshk
      For impeller using the reference which created throughout the impeller and using Boolean operation I have subtracted the impeller by keeping volute fluid domain as the source
      Please show the skewness element quality of the mesh on your fluid volume.
    • lokeshk
      Max skewness is 0.7.it is good to go for the analysis as pery knowledge.
    • lokeshk
      Is it possible share the file for my reference and learnings
      Here is the SpaceClaim 2024R2 document with three solids that use Shared Topology to mesh the two static and one rotating fluid bodies. https://jumpshare.com/v/Iqri2Rqp6OxtZg9LrGOw
      If you post a question in the Fluids channel to get help with Mulitple Reference Frame method, please add a link to that New Discussion at the end of this discussion so I can follow along with this model.
    • lokeshk
      Sure will do that.Thanks for the file
Viewing 24 reply threads
