April 17, 2019 at 7:52 am
Max4
SubscriberHi,
I have a question about the following cell macro: C_P(c,t). Does it give the static pressure? I don´t found any information about this in the FLUENT Manual.
Moreoever, the unit is the Pascal, or?
I wrote the following UDF, but I have seen UDF where the term "C_UDMI(c, t, 0) was used to store the cell value. Is it mandatory to use it?
Maxime
April 17, 2019 at 8:39 am
September 25, 2023 at 7:58 am
mechE
SubscriberHello Dr. Amine,
How can one attend a training on UDFs and expressions in Ansys Fluent? Are there any upcoming trainings?
September 25, 2023 at 9:07 am
Forum ModeratorThere are training materials on the Ansys Learning Hub, which requires a subscription.  https://www.ansys.com/training-center/course-catalog/training-for-you  That course should be pre-recorded so can be done at your convenience.Â
We also offer bespoke training, but I'd always take the standard course first. Note, the training is only intended to provide the knowledge to write the code, you'd still need to do all of the coding yourself.Â
- The topic ‘Cell Macro Pressure – UDF’ is closed to new replies.
