Cardiovascular Stent Project SIG$SEGV error
    • Nolem
      I'm using the Academic Student 2020 R2 version of ANSYS and I'm following the online course as best as possible but every time I run the solver I get this error shortly after pressing solve.
      I've already tried reinstalling and restarting the project multiple times but I still get the same error in the same place. I've also tried solutions posted on similar discussions such as deleting/moving the temp folder.
       *** ERROR ***                          CP =      2.828  TIME= 16:47:40
       An unexpected error ( SIG$SEGV ) has occurred... ANSYS internal data
       has been corrupted. ANSYS is unable to recover and will terminate.
       Previously saved files are unaffected. Please send the data leading
       to this operation to your technical support provider, as this will
       allow ANSYS, Inc to improve the program.
       Current ANSYS Traceback:
          FirstLast
          wprint
          wbest
          wsort3
          slvord
          DomainOrder
          solvcl
          ANSYS
    • Ashish Khemka
      Can you turn off the Distributed Option before Solving and see if that helps?
      Regards Ashish Khemka
    • Nolem
      Sorry I forgot to mention I tried that and it still results in the same error.
    • Nolem
      Turns out the error has something to do with the Academic version of ANSYS. Solved by going into Mesh and changing "Element Order" from "Program Controlled" to "Linear"
  • The topic ‘Cardiovascular Stent Project SIG$SEGV error’ is closed to new replies.
