April 3, 2025 at 7:17 am
tusharsant
SubscriberHi, I am new to Zemax and Ansys Innovatin Space as well. I am trying to use Car Projection Lamp setup in Ansys Innovation Courses. But the Zemax Opticstudion model for the Car Projection Lamp is not provided in the attached files. I am still trying to use the parameters visible in the video of this course. But I am not getting the correct design.
April 3, 2025 at 12:53 pm
Kirill
Ansys EmployeeThis topic has been moved to the Ansys Innovation Courses forum. Thank you!
April 10, 2025 at 9:14 am
Ashish Khemka
Forum ModeratorHello,
Are you referring to the following course? If yes, then there is an option to download the files:
Example Device for Car Projection Lamp — Lesson 1 | ANSYS Innovation Courses
Ashish Khemka
April 10, 2025 at 9:32 am
tusharsant
SubscriberThanks Ashish for the reply. This is the course which I was referring.Â
I have already downloaded the provided files. The files contain Speos files, to be used for Speos analysis. I was referring to the design they are using at the beginning from Zemax. There is no Zemax file provided. The Youtube video displays the following parameters in the Lens Data editor.
But, when I start to design on my own Zemax design using the above parameters, I get different values for surface 5 thickness, clear semi-dia, mech semi-dia etc. (displayed below)
It might be a very trivial thing, which I am missing. As I am new to Zemax, it is difficult to figure it out. It will be nice if you comment on this.
April 10, 2025 at 9:44 am
Ashish Khemka
Forum ModeratorHi Tushar,
Thanks for sharing the details. I am not aware of this field, but I will ask the team to comment more.
Ashish KhemkaÂ
- Calculation of Contact Normal and Traction Forces
- Car projection lamp Zemax design
- Torsional Stiffness calculation
- Interested in ROM building and deployment course
- Unable to login to Ansys Learning Hub
- FSI calculate OSI
- An internal solution magnitude limit was exceeded
- Correction in a file
- Foundations in Stress Analysis. Question about deviatoric and volumetric strain
- Cant find a resource file of Fluent tutorial guide
3150
1013
956
858
797
