May 17, 2023 at 10:46 pm
zakmt293
SubscriberHi,
I need some help regarding simulation of capillary action or rise in fluent. I am a PhD student and wants to perform axi-symmetric simulation of capillary rise in fluent. I have a domain which is axi-symmetric with a capillary tube placed on one side, the dimension and the boundary conditions are mentioned.
The red phase is the water and the blue phase is air. The capillary tube has a radius of 0.001 m. All the condition are at room temperature. The simulation is done at typical operaing condtion where the presssure is at 101325Pa and the operating density of air is 1.225kg/m3. On the capillary wall the contact angle is 60 degree. The water moves all the way to the top of the tube which a pressure outlet boundary. VOF method is used for modelling and implied body force is used to model body forces. Also the simulation is conducted with axiy-symmetry in x-direction and g is taken as -9.81m/s2 and the x-axis is used for axi-symmetry as per requirement by Ansys.
I was wondering if the community could provide their insight about as it is totally confusing. I would be waiting for your kind response. -
May 18, 2023 at 1:12 pm
Forum ModeratorTo clarify, you’ve set surface tension (there are two parts in the VOF panel, both on the same tab) and wall adhesion. The axis is defined as such? Where did you patch the free surface level to? What was set on the bottom & side walls? What was the backflow phase from the "top"?
As an aside. In 2d don’t select any surfaces when plotting contours etc. Fluent will figure it out, and you’ll then see a smooth colour plot as opposed to coloured cell edges as you have shown.
May 18, 2023 at 5:30 pm
zakmt293
SubscriberHi,
I have set the surface tension equal to the 0.072N/m and the wall adhesion model is used as well. Also, both the bottom and side are modelled as walls in boundary conditions.
Also, the free level is at height of 0.008m from the bottom wall. I am very thankful for your suggestion about contours and would adopt your suggestion for this later on.
Best Regards
Zeeshan
May 18, 2023 at 5:50 pm
zakmt293
SubscriberHi,
Could you help me in figuring out the problem, I have set the top of the boundary condition for capillary tube as pressure outlet. I would be waiting for your kind response.
May 19, 2023 at 9:56 am
Forum ModeratorGetting the pressure boundaries right can be awkward. What operating density is set?
May 19, 2023 at 3:49 pm
zakmt293
SubscriberThe operating density is set to the lighter phase of air which is 1.22
May 19, 2023 at 3:57 pm
Forum Moderator1.22 or 1.225?
May 21, 2023 at 6:46 pm
zakmt293
SubscriberHi,
it is 1.225, the actual density of air at atmospheric pressure.
May 23, 2023 at 4:15 pm
Forum ModeratorThat should be OK. Try extending the open part of the domain to the same height.
- The topic ‘Capillary Rise Simulation in Fluent’ is closed to new replies.
- affinity not set
3892
1414
1241
1118
1015
