3D Design
3D Design
Cantilever beam with mass and spring at the free end
    • Abdulelah
      Hi all. I'm trying to find the frequencies of the following body:
      ANSYS can drop conflicting constraints, so your results may be invalid.nThe way to address that is to create a single Remote Point scoped to one face/edge or vertex.nYou can apply several things to the same Remote Point such as a Spring and a Bonded Contact without getting the above Warning.n
    • Abdulelah
      I don't have the warning anymore but I still have the same problem n
      ,if you want someone to comment on why in 2 out of 3 cases, your hand calculation agrees with the ANSYS result, but in one case it does not, then you are going to have to write a lot of information down. You will have to describe fully the hand calculation in all three cases and you will have to describe every input to your models and insert a copy of the model .wbpz archive file into your reply.n
  • The topic ‘Cantilever beam with mass and spring at the free end’ is closed to new replies.
