March 29, 2024 at 1:33 am
Dato
SubscriberHi,
As shown above, I have read a mesh in Fluent and use TUI to read settings which is set from another computer. The settings including compiling and loading a UDF. I'm sure that name selection of the mesh is completely same for same settings. But it has some warnings when reading setting file but I ignore it and run the calculation. I have set autosave every 1000 iteration. But fluent failed to write case and data file when iterate 999. The message printed in console is shown below.
It seems that there is nothing wrong with calculation but something must happen when writing result. I did nothing but reading a setting file. Anybody can help solving the problem?
Any suggestions would be highly appreciated!!!
April 2, 2024 at 4:35 pm
Forum ModeratorThe write error is linked to the path - does that exist on the machine you're running on? The other errors are most likely linked to a lack of UDF.
Fluent set up files may contain the full path to files rather than the local path, this can cause problems with report files etc being written to odd places on computers.
April 19, 2024 at 10:50 am
Forum ModeratorDo any of my earlier comments solve it?
April 19, 2024 at 11:25 am
Dato
SubscriberI solved it by setting up the case manually though it's a bit time-consuming.
- The topic ‘can’t writing showing warning”underdefined variable and unknown property”’ is closed to new replies.
6319
