September 23, 2018 at 12:50 am
mdvanden
SubscriberHi all,
I'm trying to perform static structural on a solid part that has a specific thermal regime solution it got from Fluent. When trying to import body temperature load into mechanical I get a failed answer (red lightning) and a message saying :
--Error-- Unexpected end of file
--Error-- Required Variable 'Load Number on LOAD_NAME' does not exist
Seems to me like there is just an answer file missing or corrupt in the transfer. But I do get all my thermal results ok if I open Fluent...
Not sure what to do, if there is a bug somewhere?
Thanks, I'd appreciate any insight
September 23, 2018 at 10:26 am
raul.raghav
SubscriberCould you share the workbench archive (.wbpz) file so we could take a look at it? -
September 24, 2018 at 3:23 pm
mdvanden
SubscriberHi Rahul,
Sure, it's a pretty big file though (~17GB), is there a way I could send/transfer it?
Also, I tried again now when I try to import the thermal load Mechanical just crashes. Any hints of what might be going on?
Thanks!
September 26, 2018 at 6:58 am
raul.raghav
SubscriberCan you try exporting the Temperature data from CFD-Post and using the External Data module to import the data into Mechanical? Once you export the Temperature data from CFD-Post, check the following video on how to map the data:
October 2, 2018 at 3:15 pm
mdvanden
SubscriberSo I realized that the bug was with Mechanical. I deleted the entire mechanical model and restarted, importing CFD results. This worked fine.Â
Thanks for the help!
- The topic ‘Can’t transfer thermal load results from Fluent to Mechanical’ is closed to new replies.
- affinity not set
3892
1414
1241
1118
1015
