Ansys Products
Ansys Products
Can’t save or open Workbench project
    • wenhaoli
      for some reason, I can't save my Workbench project nor could I archive it. So i forced to close the program and found that I couldn't open the project again. The error message read: 'GuiOperation OPen...' threw exception during invoke: The tag present in the reparse point buffer is invalid.
      Can someone help me understand the issue and the way to recover my files? Thanks!
    • ANSYS_MMadore
      Are you able to provide the information shown under "Show Details"? This should give us a hint on where in the system the exception is occurring. Please share the full text.
    • wenhaoli
      Hello, i paste here the details when clicking open the 'Show Details'
      System.IO.IOException: The tag present in the reparse point buffer is invalid.
      at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
      at System.IO.FileSystemEnumerableIterator`1.AddSearchableDirsToStack(SearchData localSearchData)
      at System.IO.FileSystemEnumerableIterator`1.MoveNext at System.Collections.Generic.List`1..ctor(IEnumerable`1 collection)
      at System.IO.DirectoryInfo.InternalGetDirectories(String searchPattern, SearchOption searchOption)
      at Ansys.Core.FileManagement.ProjectFilesBackupEngine.GetFilesAndDirectoriesToDeleteForRecover(String projectFilePath, List`1& files, List`1& dirs, Dictionary`2& failedFilePaths, Dictionary`2& failedDirectoryPaths)
      at Ansys.Core.FileManagement.FileManager.GetFilesAndDirectoriesToDeleteAndReplaceIfProjectIsRecoverableByUI(String projectFilePath, List`1& filesToDelete, List`1& dirsToDelete, List`1& filesToReplace, Dictionary`2& failedFiles, Dictionary`2& failedDirectories)
      at Ansys.UI.Standard.ProjectOperationUtility.ProjectRecoveryHandler(IProtectedContext context, String projectFilePath)
      at Ansys.UI.Standard.ProjectOperationUtility.ProjectOpen(String filePath, Boolean relaunch)
      at Ansys.UI.Standard.AbstractOpenProjectOperation.Invoke(IUserInteractor context)
      at Ansys.UI.GuiOperationContext.Invoke(GuiOperationMetaData operationData)
      at Ansys.UI.UIManager.InvokeOperationCore(String pseudoname, OperationDelegate callback, Boolean allowOSMessages, Boolean coreTransaction, Boolean deferredRefreshOnly)
    • ANSYS_MMadore
      Can you try renaming your %APPDATA%\Ansys to Ansys.old?
    • wenhaoli
      Hi could you please instruct me how may i do it? I'm not quite familiar with file management ...
      Search for %appdata% in File Explorer, it's probably in C:\Users\userID\AppData\Local\Ansys and/or C:\Users\userID\AppData\Roaming\Ansys Note, /AppData is a hidden folder.
    • Connor Findlay
      Was there any resolution to this error? I have the same issue, and renaming %APPDATA%/Ansys to Ansys.old has had no impact to me
Viewing 6 reply threads
  • The topic ‘Can’t save or open Workbench project’ is closed to new replies.
