January 25, 2018 at 8:03 pm
claudeHasler
Subscriber Hi
Im trying to use AIM student version 18.1 as well as 18.2 to perform magnetics simulations.Â
Im having the same problems discussed here:Â /forum/forums/topic/can-t-run-electromagnetics-in-aim/
The problem occurs on three separate PCs running Win7 and Win10. I've tried 18.1 and 18.2. I've also tried deleting the files recommended in the thread mentioned above. I've also performed a fresh install of windows 10 on a pc before installing 18.2.
Al installations and program execution are as adminastrator
Has a fix for this issue been found yet? Is it perhaps possible to get an earlier release of AIM ( 17.0 ?) which is know to work? Can someone upload a project file generated with a working Magnetics environment? Perhaps it is just the template which is corrupted.
Regards
Claude Hasler
- The topic ‘Cant run Magnetics Ansys AIM 18.2 / 18.1’ is closed to new replies.
