Ansys Free Student Software
Cant Open meshing is only display starting mesh
    • 2210912041_alamirsyah
    • V.P
      Hi
      If Ansys Workbench Meshing stalls on the "Starting Mesh" message and never loads, this typically indicates a problem with either program settings, system environment variables, or Windows configuration. Below are recommended troubleshooting steps to resolve the issue:
      Reset Ansys Workbench Application Data
      - Open File Explorer and type %APPDATA% in the address bar. Navigate to Ansys > vXXY (where XXY is your version, e.g., v242 for 2024R2).
      - Rename the folder (e.g., v242) to v242.old or similar.
      - Navigate to the %TEMP% directory (type %TEMP% in the Explorer address bar) and rename the ".ansys" folder to "old.ansys".
      - Restart Ansys Workbench and attempt to launch Meshing again.
      If Issue Persists
      - Try updating Ansys to the latest service pack or release and repeat the above troubleshooting steps.
      Additional considerations:
      - Always run Ansys Workbench as Administrator, especially if performing the above changes.
